T-case Shifter vibrates under hard acceleration?
Discussion in 'The Garage' started by eldon519, Jun 20, 2002.
  1. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    161
    Kennesaw, Georgia
    Basically what the title says...whenever I stomp it to the floor, the t-case lever shakes like a crack addict. It's an NP205 behind a th400 behind a fairly stock 350 if any of that helps. Any ideas? /forums/images/icons/confused.gif
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Sounds like the rubber t-case mount is shot. They make a polyeurethane one that would be a good replacement...or it could be a loose crossmember or maybe a loose support rod.. I would check these 3 things.
  3. blublaz57
    blublaz57 1/2 ton status
    Feb 2, 2002
    175
    aarizona
    mine was shsken a little bit also and it turned out to be a combo of motor mount and a going bad tranny mount.im sure its going to be a mount .
  4. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Sounds like the rubber t-case pad to me, get the urethane on e and be done with it, they aren't too expensive. Mine did the same thing, until it got worse and broke the aluminum wings for the mount on my 208, had to get real creative until the rest of the case broke.
