t-case shifter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lugnut, Oct 20, 2001.
  1. lugnut
    lugnut 1/2 ton status
    Aug 3, 2001
    268
    North Carolina
    My t-case shifter vibrats and rattles like its about to fly off. It only does this when the RPMs get high (right before a shift if your on it hard or running above 70). Any one else have this problem?Its a 203 parttime I replaced the mounts and the shifter + everything else is tight.
    78 sub 454. Big as a tank and hard on my bank.
  2. Tatman
    Tatman Registered Member
    Oct 2, 2001
    80
    Indiana
    maybe a motor or tranny mount broke or loose.... making your whole drivetrain shake?
    Brian
    <a target="_blank" href=http://www.saddletramps.com/BlazerK5.htm>www.saddletramps.com/BlazerK5.htm</a>
  3. lugnut
    Aug 3, 2001
    268
    North Carolina
    Replaced the trans mounts and motor mounts are good.The drive shaft shows no sign of damage,U-joints feel good and the pinuan nut has not backed off. The whole truck does not shake its just the shifter.Im running out of ideas.
