t-case shifter
Discussion in 'The Garage' started by nicotine, Feb 6, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    okay my transfer case shifter is tight but when i start to get on it vibrates and rattles? is this normal? i have a 205 transfer case. what could i do to stop this? /forums/images/graemlins/ears.gif
  2. dyeager535
    26,982
    191
    There is a wave washer that is supposed to go between either the shifter and the adapter, or the shifter and the bolt head. If that isn't present, at least on mine, it rattles pretty bad.
    Annoying isn't it? /forums/images/graemlins/smile.gif
  3. nicotine
    Jan 11, 2004
    116
    very annoying i am pretty sure that washer is there. what else can cause this problem?
  4. dyeager535
    26,982
    191
    Only other thing I can think of if the washer is present, is that the shifter handle is hitting the body. Was doing that in my truck, but only because the transfercase was supposed to be a 208, not a 205. When the transfercase torqued over, the shifter would just barely touch the body, but it would rattle pretty bad.
