T-case shifting Technique What's your method?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FWP, Jan 10, 2001.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    T-case shifting Technique What\'s your method?
    For those with automatics and a 203 or 205 t-case, What have you found is the best way to shift the t-case from 2 hi into other gears? I am trying to get some good ideas to keep the grinding down to a minimum. I thought I might tap the experience of an awsome group of K5 owners[​IMG]. Did a search going back a year, and found really good info, but nothing as to the best "procedure". BTW, my particular setup is a 75 K5, TH350, 203 converted part time, and manual hubs. Thanks in advance[​IMG].
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: T-case shifting Technique What\'s your method?
    2HI to 4HI - keep rolling and yank the lever.
    4HI to 2HI - keep rolling and push the lever.
    2HI or 4HI to 4LO - while just barely rolling, transmission in neutral, shove the lever, being sure NOT to stop at Neutral in the transfer case.
    N to any other gear. Turn off engine, shift transfer case, restart engine. [​IMG]
  3. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    For me, this is what works best (TH350-205):2HI-4HI & 4HI-2HI- trans N, eng at idle & slow roll; in or out of 4LO-trans N, eng at idle or off & stopped. Just pull quick and don't stop in x-fer case N or you probably will have to turn it off to get it back in gear.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    That's good- rolling. Thanks guys. Are you locking the hubs first, or after, or does it matter?
  5. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    Lock hubs first...the front drive shaft needs to be turning or you are goin to be trying to [censored] a moving gear into a stopped one...dosent work well...I tried it=-)
    "Hondas look good under a k5's tires"
  6. Grim-Reaper
    7,385
    Atlanta
    First I get my wife good a liqured up. Then get her to put on her thong bikini. Then while driving about 60mph I dare her to crawl out on the hood and lock the hubs and crawl back. This gives me woo....ohhh never mind just one of them booze induced fantasy's
    on my 203 equipped trucks (75 & 79) always rolling. If going for low put the tranny in N and shift till harts content. Just never dilly dally in neutral on the case. My 75 is still full time the wifes 79 is part time. I found locking the hubs then rolling is best to do on the converted truck.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  7. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I read your post 20 minutes ago, and I'm still laughing, bad Grim, bad Grim..[​IMG][​IMG]..[​IMG][​IMG]..[​IMG][​IMG]
