T-case swap questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zakk, Nov 4, 2001.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    ok, here's the story:
    aired out the k5 and busted the tranny and t-case on the crash down. Got a 205 & 203.
    1) what is involved in a 203 to 205 swap? Driveshaft issues? new crossmember? overall lenght problems?
    2) how can i tell if the 203 is part time?
    3) all this will go behind my TH350
    as always, any help or suggestions are greatly appreciated![​IMG]
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  2. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Doubler!!!!
    You can tell if it's part time by putting it in each position, then turn the front driveshaft with the hubs unlocked. It should turn freely in 2 positions (neutral and 2wd)
    Still Poundin' "pavment" after all these years!!! [​IMG]
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the 203 is still hooked to the 350 going in. any otherway to tell? or was that with the tranny hooked in?
    -Zakk
  4. 1) you'll need a 350/205 adaptor. should be able to use your crossmember. not sure on the drivelines- should be real close.
    2) put the t case in high (not high lock) and with the hubs unlocked you should be able to turn the front driveshaft
    3) should work behind your th350 so long as your 205 will accept a 27spline input shaft.
    <font color=blue> Experience enables you to recognize a mistake when you make it again.
    </font color=blue>
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    If the front of your 203 is still good I would say do the doubler, especially if you have both the 205 and the 203. Just buy the adapter plate from ORD and the shifter. You will have to lengthen the front drive shaft, and maybe shorten the rear. But it is well worth it in my opinion. I will do this when my 208 takes a crap.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    so i take it i can count the spline count?
    also i think i should be more clear:
    the th350 is hooked up to the 203. it is all on the floor of my garage. my truck is parked at a friends house. i would hate to get the new set-up in w/o a part time kit in it and have to rip it out again. this truck is my daily driver, so it being down is terrible. so i would like to hope there is a easy way to tell if it is P/T.
    -Zakk
  7. you can swap a 203 to part time with the case in the rig no problem. all you remove is the tailshaft.
    </font color=blue>
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    awsome. i hope the tailshaft off the busted t-case is still good then![​IMG]
    -Zakk
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i was checking the length of the 205. seems it is about 3 inches shorter than the 203. any one with any info on driveshaft lengths?
    -Zakk
  10. Msquared
    Msquared Registered Member
    Oct 2, 2001
    37
    It\'s all a fog
    I thought we were just doing a straight 203/T350 combo swap.. are we putting in the 350 and the 205?
    Try get hold of Chris yet?
    call me on my cell...
    -Marcus
    -Just me, trying to have fun
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    no reply from allen on the 465/205
    gonna call chris now...
    -Zakk
