t-case???
Discussion in '1992-Present Chevy & GMC models' started by ksblaze83, Nov 17, 2004.
  1. ksblaze83
    ksblaze83 1/2 ton status
    Sep 11, 2004
    329
    Topeka, KS
    I have a 99 silverado and it has a 261 t-case, but I was under the impression that only the auto trac t-cases were the 261. I have a lever for the shifter, not the push button 4x4. It's not the full time 4x4 so i'm confused? Anyone have any info on the 261 w/the mechanical linkage, and the push button and the differences (besides the obvious 1 is electronic one is mechanical). Thanks
    /forums/images/graemlins/thumb.gif
  2. muddog
    muddog 1/2 ton status
    Jan 23, 2003
    262
    Cadmus, KS
    this is a copy and paste from a 4 wheeler mag tech article. Hope it helps
    ’98-to-present GM ½- and ¾-ton pickups, Tahoes, Suburbans, Yukons, Denalis, and Escalades
    What you’ll find: NVG246
    Type: Autotrac part-time case that always spins the front driveshaft, aluminum, chaindriven
    Low range: 2.72:1
    ’99-to-present ¾- and 1-ton GM trucks
    What you’ll find: NVG261
    Type: Part-time, magnesium, chaindriven case
    Low range: 2.72:1
    ’01-to-present ¾- and 1-ton GM trucks
    What you’ll find: NVG263
    Type: Part-time, magnesium, electric shift, chaindriven case
    Low range: 2.72:1
    ’98-to-present GM ½- and ¾-ton pickups, Tahoes, Suburbans, Yukons, Denalis, and Escalades What you’ll find: NVG246 Type: Autotrac part-time case that always spins the front driveshaft, aluminum, chaindriven Low range: 2.72:1 ’99-to-present ¾- and 1-ton GM trucks What you’ll find: NVG261 Type: Part-time, magnesium, chaindriven case Low range: 2.72:1 ’01-to-present ¾- and 1-ton GM trucks What you’ll find: NVG263 Type: Part-time, magnesium, electric shift, chaindriven case Low range: 2.72:1 ’99-to-present Ford Super Duty and Excursion What you’ll find: NVG271 (manual shifter) NVG273 (electronic shifter) Type: Part-time, magnesium, chaindriven case Low range: 2.72:1
