T D S RUN CARNAGE for me at least hehe
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K10ANDYKHAMNIC, Mar 4, 2002.
  1. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    1 right front u joint
    1 right front hub fusible clutch ring
    1 208 dodge tailhousing
    all on one obstacle! too much go pedal i guess heh heh
  2. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    Isn't it kinda insulting to lose both the u-joint and the fuse?
  3. Grim-Reaper
    7,385
    Atlanta
    Warn point blank says if the wheels are turned full lock that it changes the stress on the joint and the fuse may not blow before the u-joint. They have rated the thing with the wheels straight. If they went any lower it it would be poping to often.
    Fair warning about fuses and front lockers. Seems a lot of lockers will get damaged when those fuses let go. Still may get the same damage if the u-joint blows so it's a hard call. At least if the fuse blows your not risking the ears on the shaft getting damaged or worse yet taking out the ball joints.
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i missed a good show, you intereseted in that d60 i told you about. i'll be checking this weekend to see if it's still there.
    ARQ.
  5. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    no not really like what grimy said . i agree . sure ARQ check on that for me . i am devising a new t case so i might need a 205 .
  6. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Glad you made it back home, oh and you don't need that dana 60... so you can just pass it to me!!!
