T-shooting the fan/blower...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MrBob, Aug 21, 2000.
  1. MrBob
    MrBob Registered Member
    Jul 27, 2000
    52
    ..in the heater A/C interior....just suddenly stopped,,,changed the fuse with no resolution...any ideas...?
    Red Springs, N.C.
    "I ain't responsible for my crappy typin' or spellin'"
  2. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    Was the fuse bad, or did you just change it? Do you have voltage at the fuse, what about the blower motor? You may have to pull the plug on the motor, if it is drawing too much current, to see if you are getting voltage there. If so, is the blower motor properly grounded? You can pull the motor and hook it up to your battery and see if it is working, a couple of alligator clips and some wire. Just make sure you hook it up right ( positive and negative), it shouldn't really matter though, but just in case. - Steve
    Steve Sosa a.k.a. "sosaman"
    http://sosaman.home.texas.net/carpics.html
  3. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    same thing just happened to my dads plymouth. run the fan directly off the battery, just not for long if that works check contunity (resistance test) the wires to and from the controler the motor and the supply. if you didnt smell a burning smell before the motor craped out its probably just a bad connection.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Just FYI, I've had a blower motor just quit..........like quit all of a sudden, with no friggin' warning, right in the middle of a Canadian prairie blizzard at -28C!!!!! Anyhow, enough crying- just wanted to say the fan motor could have just died.
