T-stat, Rad cap
Discussion in 'The Garage' started by 79cheyenne79, Nov 16, 2006.
  1. 79cheyenne79
    79cheyenne79 Registered Member
    Aug 14, 2005
    29
    maryland
    I have a 79 Cheyenne with a 350. I was wondering should I go with a 195 t-stat. And how many pounds should the rad cap be. Im asking ya'll before I do all of this research..:bow:
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    as long as your cooling system can handle the 195 t-stat, and keep the engine around that temp, then i'd go with it, especially since you are back east, and have some serious cold weather, will provide you with some nice heat, and keep things running nice and comfortable.
    16psi cap too, that's usually what they all are.
  3. diesel4me
    Jul 24, 2003
    17,540
    927
    Massachussetts
    195 is what you should use!..
    GM has used 195 degree thermostats since 1968 factory in all vehicles..anything lower will reduce heater output,increase emissions,and waste fuel due to longer warm up times,and could lead to oil dilution....some new cars use 210 degree thermostats!..:eek1:
    I've never seen any engine that had an overheating problem cured by swapping in a lower temp thermostat,all it does is make it take a few moments longer for it to overheat..you want the motor to run as hot as possible, without causing overheating, for maximum efficiency and fuel economy..:crazy:
