t-stat replaced
Discussion in 'The Garage' started by 79cheyenne79, May 16, 2006.
  1. 79cheyenne79
    79cheyenne79 Registered Member
    Aug 14, 2005
    29
    maryland
    i changed the t stat im letting the silicone dry overnight and hopefully i wont see that problem any more. I got a t-stat that is set at 160 is that cool? i think its suppose to be set at 180
  2. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    too cold...
    All Chevy motors since 1968 came with 195 degree thermostats..its especially important to use them on the newer EFI and computer controlled motors..the motor can run cool enough to not come out of the "open loop" and run off the ECM... the coolant temp sensor "thinks" the motor is still "cold",and that will cause poor performance ,and horrendous gas mileage..it'll make the motor sludge up bad in cold weather too,takes longer to burn off condensation in the crank case..
    Only time you need a 160 degree one is if a special "chip" is installed in the computer..I've never had any success curing an overheating problem using a lower temp thermostat in a GM motor...every time I tried one it just took a bit longer,but it still overheated..and I'd find the REAL problem later,like timing being off,bad head gasket,clogged radiator,etc...I find the hotter a chevy motor runs,the better it runs...within limits of course..:crazy:
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    too cold IMO,,,,either 180, or 195, depending on time of year for me.:D
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Are you sure you didn't mean 1986? I know for a fact that 180* was used up until GM went to ECM's, not sure about the early ECM carb/dizzy models but FI for sure.
  5. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    what I read..
    I read in a GM manual when they introduced the "CCS" (Controlled Combustion System) in 1968,it consisted of a 195 degree thermostat,recalibrated carb jetting,distributor advance timing,and in some cases an AIR pump system to increase eficiency and lower exhaust emissions..as far as I know they used the 195 thermostat from the factory ever since..
    I wouldn't go lower than a 180 stat myself..I like having a heater that works,and getting good gas mileage is an absolute must nowadays..:crazy:
  6. dyeager535
    26,980
    Yeah, do some more checking, 195* is pretty much standard GM fare from 1960's-90's+ Olds, Cadillac, doesn't matter, all 195*.
  7. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Too cold. use a 195. Your engine will thank you.
  8. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I run a 160 t-stat and I have had no problems what so ever. If your engine is non computer controlled then you can run whatever temp t-stat you want.
  9. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    So long as you don't consider less fuel mileage and increased engine wear " problems" yes it will be fine.
    You might want to do some tech research on the subject.
  10. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    How would it make that much of a difference? I have no computer anything on my engine and I keep the timing and carb in adjustment, so I fail to see why this makes that much of a problem.
  11. Kyle Strong
    Kyle Strong 1/2 ton status
    Sep 26, 2005
    280
    Eugene, OR
    Because not everything expands properly, oils properly, etc, and the engine will wear prematurely.
  12. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    And also, Especially on short trip driving, condensation collects in your engine. This moisture does nothing good in your engine and if your running cool it does not " evaporate as it should. These are fine points and it really boils down to how much you care about engines. Ever notice how some people always have better " luck " with there cars performance and reliability? I don't believe it's luck. Never have.
    I mentioned do some tech research not in a smartass tone, just to let you know that there is some great info out there on this subject that explains this far better then I ever could. Try GM tech. If you don't think the little things matter, ask Jack Roush.
