T*ts up.........
Discussion in 'The Lounge' started by dontoe, Sep 18, 2006.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Oops.....
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I wouldn't want to be inside...
  3. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,003
    826
    Pinckney, MI
    OUch thats going to be fun flipping over
  4. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Did that fall off the bridge too? Now I know why the other one was turning left. He was following this one :haha:
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    "do you see my lunch anywhere around here?"
  6. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Ive got a pic of an LAV-25 somewhere that looks very simialr to that, Ill have to try to dig it out
  7. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    I wonder if it has a roll cage?:doah:
  8. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    being inside there would suck... but those guys can thank their lucky stars that they didn't fall into a body of water....
    j
  9. chevyfumes
    Feb 24, 2000
    38,584
    266
    Thanks for that visual,now I got the heeby jeebys...:eek1:
  10. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    yeah, definitely bad times. We lost some guys early in Desert Storm II this way... LAVs or tanks or whatever falling off bridges into various rivers. Bad times indeed. Even if you had the equipment to pull the tank out of a good sized river, there is NO way you could do it in time to save the crew inside... :(
    j
  11. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    No way to equalize pressure so the hatches will open then?
    Stoopid engineers, how'd they miss that one? Seems like that would be on the primary requirements list.
  12. chevyfumes
    Feb 24, 2000
    38,584
    266
    Oh I'm sure the pressure equalizes but that won't do you any good if you're upside down.:crazy:
  13. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    is a tank or APC 100% air tight? even if it is, it doesn't have an unlimited supply of oxygen for the crew to breath. Pretty small crew compartment on a tank... not enuff room for 4 guys + hours worth of air to breathe...
    j
  14. chevyfumes
    Feb 24, 2000
    38,584
    266
    They must have some sort of fresh air supply, be kind of a bitch to have to crack the lid in the middle of a hot zone to get some fresh air???:haha:
  15. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I don't know about the A2's, but the M1A1's NBC system draws outside air through filters (think gas mask filters, but bigger) and over-pressures the hull slightly. Positive pressure eliminates the need to perfectly seal the hatches and the turret ring.
    I try really hard not to think about what it must have been like for the crews of the M1's that have gone off bridges & canal banks into the water and ended up inverted. Nothing to be done for them - the vehicle is too heavy to be righted and pulled from the water before the crew either drowns or asphyxiates.
  16. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    X2, makes me sick to my stomach reading the articles about that.
