T.V. Cable question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nofeartruckin00, Oct 10, 2002.
  1. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    Hindsight is always 20/20, should have asked about 2 days ago. Finished the 2" body lift, and the T.V. cable came to mind for some reason. Its a 4L60E in a '91, should i have done something with the cable? Actually, its a little late for that. Is there an adjustment i should make before driving it? Searched the forums, no luck. Thanks everyone!
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I dont think a body lift will change the TV cable adjustment. As long as it is shifting ok like it used to it should be fine.
    But the shifter linkage from the steering collum to the trans may need to be adjusted.
  3. nofeartruckin00
    Oct 5, 2001
    798
    I welded on an extension for the shifter, and thats what made me think about the TV, just wasn't sure if it was affected by body height. Thanks!
  4. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    if you added a body lift to your truck and the tension on the tv cable did not increase or decrease you should be fine. Usually tv cables are a bit longer than needed anyways. If you feel a diffrence in shifting. Then most likely something is wrong. But you should be okay.
