t400 bellhousing or adapter plate?
Discussion in 'The Garage' started by muddyblzr, Nov 22, 2004.
  1. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    i got an offer today for a turbo400 that came out of a cadalac and the bellhousing wont bolt up to a chevy engine. im not a tranny guy at all but is there a way to get a bellhousing from one or is there an adapter plate. the guy wants 20$ for it and it worked when it came out and the fluid is still good. anyone know anything about bellhousing or adapters?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    adapter plates are available on summit or jegs. Any race shop should be able to get you one. Someone makes a really beefy bellhousing but to change an auto bellhousing requires cutting off the old one and having a custom one that bolts to the pump housing bolts.
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    they make a bop engine to chevy tranny adapter, it would prolly work the other way also.
    u could buy an ultra bell housing, cut your bellhousing off & bolt the new one on to the tranny frt pump.
  4. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i type too slo your post wasn't there when i started.
  5. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    If you guys are thinking about Baddog, he later found that only a small high stall converter would fit in the Ultra Bell. As far as the Caddy 400 goes, there are plenty of Chevy 400's out there and you would be better off with a Chevy K case anyway. Find a bad one and have the guts swapped.
  6. muddyblzr
    Nov 2, 2004
    623
    i think thats what im gonna do buy it cuz its so cheap and swap the guts out and find a torque converter with a low stall speed so i dont chew it up like my friend did. stupid high stall and high gears /forums/images/graemlins/whistling.gif
