T400 question
Discussion in 'The Garage' started by crazyrc, Oct 9, 2005.
  1. crazyrc
    crazyrc 1/2 ton status
    Jan 20, 2003
    106
    Northern Alberta, Canada
    Can anyone tell me if I need a vacuum modulator on my new T400. I bought a TCI T400 and the general instructions state that you need to make sure to install a modulator if your tranny needs one. I know my old T400 had one in it.
    Should I re-install it on this one. This is a fully race prepped reverse manual valve body transmission. Its installed and I'd like to go wheelin, but I don't want to bugger up my new tranny.
    I can't get a hold of TCI until tommorow.
  2. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    is the old one bad? im not real keen on transmissions so i doubt id be of any help. any who the reason i posted is that i the valve body is the same way in the 400 i took out of my k5. the po did it and i cant stand it. what is the purpose for setting up a valve body that way?
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    You should always install a new modulator on a new trans mission. The only thing i don't know is wheater or not you need one with a full manual valve body
  4. crazyrc
    Jan 20, 2003
    106
    Thats what I'm not sure of. Its possible that I don't need it at all. Can anyone tell me what effect it has on the shifting.
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    It tells the Transmission the load condition of the engine it works with the govenor to determine when to shift for example if you floor it the modulator will get almost no vacum and will hold the shift out longer if you are just driving normal it will get more vacume and will shift sooner. You can try it with out it hooked up and if you can not get out of first gear you will know that you will need it. It will not hurt to just see if it will shift being careful.
  6. crazyrc
    Jan 20, 2003
    106
    Thanks.
  7. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    You dont need the vaccum mod with a full manual valve body. When I installed my manual valve body it came with a plug that went in the bore where the modulator goes. When they put those valves in they put in a heavy spring in the pump that already bumps the line pressure up to max. Just put the mod in there (if you dont have that plug) and cap the mod with some vaccum caps.
  8. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Oh and by the way they usually take the governor out when the manual valve body goes in. :waytogo:
  9. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    This was rather informative, I haven't read that far in my TH400 book yet.
