T400 Tranny folks, downshifting questions
Discussion in 'The Garage' started by bobsurf, Apr 14, 2003.
  1. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    I'm trying to figure out my buddy's problem he's having with his '86 2wd 3/4 ton. He's got a T400 in there, and I know very little about them (I've got a TH350). He's having problems with it not wanting to downshift when he either kicks it down, or just regular driving (from what he told me).
    What I've read so far:
    There is a kickdown switch hooked up to the skinny pedal. I'll check to make sure that's working (i.e. ignition on, hook it up to a light, floor it).
    From what I read, there isn't a TV/Detent cable, but instead is just controlled by the vaccum modulator. Where is that? Is that what we should check next? Is there anything else that plays a role with auto shifting?
    Thanks in advance.
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    There should be a vacuum line from the back of the manifold to the passenger side of the trans, where there is a modulator. The switch for the kickdown is on the driver's side. The vacuum line specifically controls the upshifts. Not much help...sorry. /forums/images/graemlins/crazy.gif
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    The kickdown is an electric operated solenoid, located on the valve body in the trans.
    Pull the pan, make sure You have a signal when the pedal is pushed to the floor, or You might get lucky, and the connector has simply fallen off of the solenoid. /forums/images/graemlins/grin.gif
  4. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    Check to see if the oarnge wire had fallen off the trans on the drivers side. I've seen this happen alot on the TH400 trannys. /forums/images/graemlins/thumb.gif
  5. bobsurf
    Jun 26, 2001
    410
    San Marcos, CA
    Thanks Everyone, I'll do some more investigating.
