T400 w/ a NP241, Will it adapt to a 203-205 doubler?
Discussion in 'OffRoad Design' started by chvyhs, Nov 7, 2003.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Like the subject says. I have a T400 with a NP241 and I want to know if I can put a doubler. It's in a '90 Suburban so length isn't a real factor. I read everything on the ORD website and it didn't meantion using a T400 that originally came with a 241. I already have a 205 lined up so before I go though the trouble of finding a 203 I want to know if I need to find another trany. Thanks
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    The 400 output shaft will be a hair too long. You need the actual 400 tranny that had the 203 behind it or just swap the output shaft if you can find one. /forums/images/graemlins/thinking.gif
  3. chvyhs
    Feb 12, 2001
    1,469
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    There's another way, we've had good luck drilling the front face of the 203 gearbox to mount up in place of a 208/241 'case. It takes a few tweaks here and there but it indexes properly and the shaft is usually the right length or close enough that it's not a problem. This way you don't have to even take the trans out of the truck to put the Doubler behind it.
