t700r4 downshift problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by audacious, Mar 31, 2003.
  1. audacious
    audacious Registered Member
    Mar 10, 2003
    34
    tx, austin
    /forums/images/graemlins/k5.gif before i take my truck to the shop tomarrow to pay a tech 80 dollars to make me look like an ass i figured i would give you guys the honor of doing it for free. OK heres the deal.i have read all the post and still haven't gotten the right info i need. help. I have just rebuilt the top end of my engine. replaced the intake manifold and carb (edelbrock proformer matchup)etc.replaced all vaccum lines and the dentent/TV cable. I have adjusted the cable to everyones specs and i still have a definite problem shifting. if i adjust the cable to full throttle i get great up shift but no downshift at all. when i adjust it to the middle thottle i get high rpm but no real shift. when i have no cable adjustment i cannot move the gas pedal. WTF i can manually shift fine but no auto shift. /forums/images/graemlins/confused.gif please help me save my time and money. Thanks
    P.S. as far as the rest of the engine goes it runs great.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You didn't say what carb you put on but if its the 1406 performer carb.
    I think you need an adapter for the carb linkage to get the right geomerety for the cable. The TV valve is very touchy and requires the cable to be hooked up to be pulled out a certain way. If it is not hooked up and operating right, you can destroy your tranny in a very short time.
    Unless the carb you are using is designed to work with a 700r4(most aren't) you will need an adapter. Most of those 1406s are made to work with TH350 and 400s.
    Go here to get more info:tvmadeezy.com
  3. audacious
    Mar 10, 2003
    34
    tx, austin
    thanks for the info. yes i do have that carb( which is a replacement for the original) but i have talked to a tech and he said all i have to do is use the origional cable mount that holds the cable in place and level the cable until i achieve the correct adjustment.that adapter plate he said was a waste of money.
  4. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    contact 84k5cedric...he's done work on makeing carbs work with 700's
  5. audacious
    Mar 10, 2003
    34
    tx, austin
    hey guys thanks for all the help i fixed it and works great ended up taking the pan off and resetting the hook inside the trans for the tv cable. then replacing it back on the origional bracket and adjusting it off the carb. worked like a charm only took an hour.
