Tac mounting.....
Discussion in 'The Garage' started by dirtwarrior17, May 11, 2005.
  1. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    Where do you guys put your tac? I have an 88 k5 and my dash is pretty much gone... i already have about ten holes in it from trying to find a sturdy spot to mount my tac but every time i think the screws are set it wobbles and falls off. I can't put it on the steering column because its too big and i want to be able to still have my eyes on the road when i check rpms.
    Any suggestions?
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    A-Pillar/Dash Corner. I used the screw that holds the trim on to attach my 5" monster tach....
  3. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    Got any pics?
  4. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Sure, lemme find em.....
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I put my cheapy Tach in the corner using an existing screw , and ran my wires next to dash and down to fusebox . Bent the bracket that came with it and used an existing hole in bracket .
  6. johnnyclueless
    johnnyclueless Registered Member
    Nov 26, 2004
    51
    I had the same problem with mine loosening up while on the trails. Just set the strews again and coat the screws in some good epoxy or glue. That should fix your problem.
  7. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    No screws, just zip tied to the column
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    That's exactly where mine is! I used a hose clamp though, and mounted it farther down toward the dash. When I was all done I realised it rotated when I moved the shifter! :doah: Good thing it's not an automatic anymore...
  9. TDAWG1
    TDAWG1 1/2 ton status Premium Member
    Jan 18, 2005
    2,836
    8
    Grand Junction, Crawlorado
    Question
    How does a Tach work.? I mean how do you hook it up? Is it just electrical wires or is it like a speedo cable? I have wanted one for a long time only I was afraid it would be difficult to set up. When you set it up how do you know it is accurate? Can you tell me. Maybe it is so simple I could have done it easy. I just don't know. Thank you :cool1: :grin: :o ;)
  10. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    with a hei distrubutor, you just plug it in next to the hot lead, then hook up the light and ur ready to go.
  11. TDAWG1
    Jan 18, 2005
    2,836
    8
    Light what light is this the shift light???????? AHHHHH I feel like an idiot........Ok Im over it.
  12. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Light like in your dash, so you can see the gauge while driving at night.
  13. TDAWG1
    Jan 18, 2005
    2,836
    8
    Well now that makes since, :o How much does an HEI distributor run? I am probably going to run a MSD set up. From the ignition all the way thru.
  14. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    If this is for your 87 Jimmy, it already has an HEI distributor :thumb:
  15. TDAWG1
    Jan 18, 2005
    2,836
    8
    Man thanx 4 da knowledge, So what is a good Tach and how much?I knew of one gage company but the name excapes me at the moment.
  16. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Autometer :thumb:
  17. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    That's exactly where mine's mounted too...
  18. TDAWG1
    Jan 18, 2005
    2,836
    8
    Is it easy to calibrate? :cool1: :grin: ;) :D
  19. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    calibrate....:haha:
    If you're talking about accuracy, don't worry about that, there's a switch to set how many cylinders it's for, that's it. The shift light isn't hard to do either.
  20. whiskey bent
    whiskey bent Registered Member
    May 24, 2004
    49
    Alabama
    not sure if it'll werk on a auto truck, but just get a big hose clamp and clamp the mount to the steering column, mines still easy to see, with a stock gmc wheel anyway
