tach and other guage needles?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Feb 1, 2001.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I installed a stock tach insturment cluster in my 73 today.
    The guy i got it from had taken the needles off to refinish the black background, and then put the needles back on, but they are not zeroed.
    For exampl, my tach at 0 rpm (not started) reads just under 1000. It IS supposed to read 0, right? So I should just remove the needle and point it at 0, I guess.
    But what about the ampmeter, oil pressure guage, fuel guage, and temp guage? Should they be resting on the little stop past zero, or be right at zero?
    Anyone see what I am talking about?
    BTW, the stock tach is great. I didn;t realize I was revving it as high as I was. Even calculating for the error (not zeroed), I'm still pushing it to 4500 or so on a regular basis. No wonder it needs a rebuild (lol).
    -- Mike
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    All my gauge needles are resting on the zero.
  3. KENBARBOUR
    KENBARBOUR Registered Member
    Jan 14, 2001
    54
    All mine rest on zero. But i've got a good question. How come every tach i hook up works fine for about a week then the needle dances all over the place? I've checked all the wires. Does it have anything to do with the HEI?
  4. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Are the grounds getting fouled/corroded? Are the conections loose? Are the wires getting too close to the plug wires?
    " What day is today?....Febuary.....Its nudie magazine day!!!!!!!! " - Billy Madison
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    All are all way off.. Untill I turn the key to run/start-run... then they auto dial in and go to work... Check your ground from your frame to the battery and the battery to the body... These connectuions are in the engine compartment.. I had this same problem and I added a ground to my battery and it all went away... I discovered this after a new alternator, new oil pump (installed by yours truely) and a new battery and cables...
    It was all a ground...SO CHECK YOUR GROUNDS!!!
    Um... yes officer I know it's too big...
  6. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    My 78 k10 with factory tach sits at about 1000rpm mark with the key off. When you turn the key to run it will go to zero. Rest of gages needles rest on stops.
  7. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Ok, I've thought it through a little more. Tach and mech oil pressure guage should be zero with the key on. No problem. With regards to temp, ampmeter, and fuel, I read the responses (thanks!) and one person said they should be on zero and one person said they should be on the stops.
    I'm guessing it should be on the stops with the key off and zero with the key on (except ampmeter of course).
    Am I understanding this right?
    -- Mike
  8. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    Ditto DMK. My 87 factory tach does not zero until key is on. Otherwis it sits up around
    1 grand. This called a taut band meter I think.
    SteveB
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The factory tach that was in my '77 K5 would sit at just under 1000 with the key off. Key on, engine off and it would drop to zero. If this is how yours is behaving, then I think it's OK.
