Tach Bouncing??
Discussion in 'The Garage' started by MTBLAZER89, Oct 3, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    My tach bounces about 200-400 RPM's until I hit 3000 RPM's then it is smooth until it shifts. I can't "feel" anything wierd while it is doing it. The coil and pickup both checked good. No codes. Also it idles about 500 RPM's when it is warm /forums/images/graemlins/confused.gif
    1989 350 TBI.....Any ideas?
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    My OE tach acts really wierd when the alternator is failing.
    /forums/images/graemlins/thinking.gif
  3. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ] You guys have factory tachs? NO FAIR! /forums/images/graemlins/grin.gif /forums/images/graemlins/frown.gif
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Nope mine is a Sun Meter........Any Ideas
  5. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Mine does it also, not sure what brand but I haven't been able to fix it on my 88 V3500 454
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    by chance, do you have access to an inductive digital tach? check and see if it's actually accurate? I know some of the "less expensive" tachs are prone to this, But i had a problem with a autometer tach that did that. I had to use a signal wire with a stainless sheild over it. The signal going in was affected by the "rf" put out by my ignition system. It was not noticeable at higher rpm's because the pulse signal was faster.
