Tach cluster for sale, cheap and great condition on ebay (not mine)
Discussion in 'The Garage' started by 86haubs, Jul 3, 2006.
  1. 86haubs
    86haubs 1/2 ton status
    Nov 14, 2005
    196
    Lemoore, CA
  2. berserker
    berserker 1/2 ton status
    Nov 19, 2005
    127
    columbus,ohio
    i never knew they came tachs
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    81 was the last year it was an option on the C/K line.:D
    I have never seen a complete 81 set before and that one looks nice. I got mine from a 79 set and the gauges were pretty beat and I had to get the tack repaired but it works great now:D
    Ira
  4. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    wow im gonna give it a shoot, hope i get it!!!! thanx for da info, it woudl be sweet for my truck.LOL my 1979 didnt come witha tach and it has a 350, sm465???
  5. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    I know in the 1987 wiring diagram it DOES show a tach option!! Spent darn near three months working on getting factory guages into mine. So I have studied the wiring Ds
  6. sandawgk5
    Oct 28, 2003
    6,881
    It does show the option but the actual option for a tach was removed from the lineup in 81. I too have studied the drawings. I also learned that for my application it was a plug n play event.
    Ira
  7. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    i lost :( it was fun trying though!!!!LOL does any body have 1 laying around that there willling 2 sell??
  8. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I'm not so sure on this. I haven't had much luck swapping around gauge clusters because they were wired different.
  9. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    I am not sure on the fitment for all the years either. I guess with a little work anything will fit. I know the wiring and the circuit board on the back is different between models and years, so how would that work?
  10. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    This is what I had to do. I traced the circuit sheet on rear of gauges and then wrote what each contact went to. I then took the cluster plug and rearranged each pin so that it was the right spot. I had a 1989 Jimmy for donor so I had wire plug to compare also. Just had to add an extra ground wire and change out the sending units for oil and temp.
  11. sandawgk5
    Oct 28, 2003
    6,881
    The one I used for my 87 just plugged right in. Maybe it is a hit or miss type of deal.
    Ira
  12. divorced
    Jul 20, 2004
    5,115
    The problem I had was swapping the mechanical gauge clusters into the electric gauge cluster trucks. It would be difficult to just swap this sellers electric gauge cluster into an older truck that had a mechanical gauge. I think a lot of the wiring changed around '80 or '81 also.
  13. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I bet it will bring some large coin, the ones in the past have:rolleyes:
  14. divorced
    Jul 20, 2004
    5,115
    Maybe we could try to guess what it would sell for? I'm guessing around $225.
  15. sandawgk5
    Oct 28, 2003
    6,881
    Mine was all electric but since I have an 87 I had to keep my 87 speedo for the VSS Signal. I took my 87 housing and cut the back of the large gas gauge area out so the tach would fit and then used the tach printed circuit and all of the pins in the connector lined right up and it bolted right in:D .
    Ira
  16. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    That link at the top shows a current auction....???
  17. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    What I was refering to was the idiot lights to gauges. The tach install I didn't even try because I have no need for one.
  18. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    they did put them in after 86
    I have a tach cluster out of a 86 1-ton dually that had a 454/th400
    that came factory, I got the truck from the orginal owner and he said it came that way, he did not add it, It pluged right in to my 79' K-5
  19. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    [=big94gmcquote]That link at the top shows a current auction....???[yeah its current]
  20. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    I checked it this morning and it was at $93. I am guessing $175
