Tach. cluster
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by slider, Feb 23, 2006.
  1. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    I am selling a tach cluster that was in a V8 to a member. He has a six cylinder in his truck. Our question is will this tach cluster from a V8 work in six cylinder. I have seen where aftermarket tach's are adjustable for different ammounts of cylinders but factory ones are not. Any help is appreciated. Slider
  2. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    im pretty sure it should work...im not positive but i dont think the number of cylinders matters its checking how many times the...crap i forget what it is but it might work..someone might chime in with a better response
  3. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    Won't work and tell him good luck finding a S6 factory Tach I've never seen one and if you did you could probly swap a v8 in for less than it would cost. :eek1:
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    All the aftermarket tachs I've seen have a 4-6-8 switch; like he said, never heard of a factory L6 tach. The whole panel/cluster might be a neat starting point, with the small gas gauge over on the left and use an aftermarket tach.:D
  5. dyeager535
    26,975
    GM made some "adjustable" (6 or 8 cylinder switch) tachs, but they weren't used in trucks, sorry. 25% error in RPM due to # of cylinder difference.
  6. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    if ur friend wont take it still i might
    what year did it come out of...i have a 90 will it work?
  7. dyeager535
    26,975
    Not as it is.
    1990 uses the electronic speedometer, as of yet no one has provided proof that the tach was ever available after 1981-ish.
    You can of course swap the gauges around, but the tach cluster is specific in most regards (cutouts in the plastic housing, printed circuit board, etc) and the 1990-91 PCB/housing is much different than even the 1981-1989 cluster housing with the same non-tach setup, as is the wiring.
  8. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    I might have one of those. I bought a cluster off ebay. he said it came out of a chevy truck. it is the same as our blazers. Except. my tach shows 4500 rms at 60 mph. And i now that is wrong. It has a seperate plug in for the tach only. It is not attached to the main wiring. oh and i have a 75 k5
  9. dyeager535
    26,975
    No, the ones I'm talking about came in the A/G-body cars, I BELIEVE it was the Olds' only. There is a switch on the tach circuit board that is moved between "6" and "8" for the different engines.
    The plug on the truck tachs is separate for all years that I'm aware of. 3 wires: 12V ignition, ground, and the signal.
  10. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah slider, i didnt think it would work. I totally forgot about that little detail too until last week. Oh well, guess I wont get to get that factory tach setup in the truck like I wanted.
  11. slider
    May 7, 2001
    547
    Not a problem, Glad we could work it all out. Slider:D
