Tach hook up?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78K5395MT, Oct 13, 2002.
  1. 78K5395MT
    78K5395MT Registered Member
    Aug 31, 2002
    27
    Winston-Salem, NC
    Um. . .yeah, basically i don't have an electronic ignition so where do i hook up a tachometer to?
    thanks
  2. Grim-Reaper
    7,385
    Atlanta
    No electronic Ignition? what does it use? flints? /forums/images/graemlins/grin.gif
    You would use the same terminal that the points trigger the coil with The negative.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    You should have an HEI distributor in your 78. There should be a termenal on the side of the distributor marked Tach, right next to where the Batt. (Hot wire) connects.
