Tach hookup help needed ASAP please
Discussion in 'The Garage' started by Wingnutt, Feb 7, 2004.
  1. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    I'm in the middle of hooking up a tach to my '88, and I ran into a little problem. I know I need to hookup the tach pickup wire to the (-) side of the coil.....but this coil has four wires coming out of it. And they are not labled. /forums/images/graemlins/whistling.gif There are two red wires and two white wires. One of the white wires has a connector on it labled PED. Is this the tach hookup? /forums/images/graemlins/dunno.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    One side of the dual connector should hook up to your distributor. The white wire on the other connector is your tach wire. One wire of the connector that doesn't go to the dist is you power wire (red) and the white is the tach.
  3. Wingnutt
    Feb 20, 2000
    324
    NOVA
    Thanks a lot for the quick reaponse. I haven't had the time or $$ to mess with this thing too much, but I can dream can't I?
  4. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Isn't it marked "tach" on the GM HEI, distributor cap?
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    If it is an internal cap coil (big cap) HEI then yes it should be marked tach, but it sounds like he has the dual connector external coil on an 88 TBI truck (small cap HEI).
    Harley
