Tach install -- Need some words of wisdom
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5thatShmobs, Nov 17, 2002.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Im putting an auto meter tach in my '89 K5, and I was hoping that someone with any knowledge on this with blazers in particular could give me some advice. Basically I'm trying to find a good places to connect the positive, ignition switch, and dash lighting wires. Any suggestions?
  2. Grim-Reaper
    7,385
    Atlanta
    Fuse box. THe fusbox has tons of Accessory connections in the top. Clearly marked "BATT",, "IGN" and Accessory. THe light I would tag the light circuit on the harness for the radio. That way it will dim with the rest of the dash lights. I think the wire you looking for would be brown with a stripe. Take a test light and probe the wire. Turn on the parking lights and twist the dimmer to see if you have the right one.
  3. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Thanks for the really good advice... Ill follow up.
  4. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    That should work well.
    I pulled all three (+12v,ground, and panel lights) from my radio harness on my '74 and it worked just fine.
    Good Luck,
    -Ben
