Tach install
Discussion in 'The Garage' started by k5 bray, Jan 1, 2007.
  1. k5 bray
    k5 bray Registered Member
    Nov 29, 2004
    18
    Cypress TX
    Which wire do I tap into for the dimmer function to work?
  2. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    everytime i play with gage lights they are yellow wires. The extra tach i have in my garage also has a yellow wire for the light, which if you wire to all your other gage lights should be able to be dimmed with your dimmer switch.
    I'm not sure if thats what your asking though.
  3. k5 bray
    Nov 29, 2004
    18
    Cypress TX
    Yeah thats what i wanted to know. Thanks
  4. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    highjack
    since the question is already answered, how about a minor highjack...i have a sunpro tach that worked great with my old '82 350 and hei, but now, i have the old hei on my remanned 350, and the tach no longer works. i unhooked ONE related wire when i pulled the dizzy. it was the green tach-to-dizzy wire. after i hooked it back up, it worked, briefly, but now, will not. all my connections are exactly how i originally made them, and have proper voltage supplied (i put my meter on it). do the TACH terminals on these hei coils short out easily or something? maybe a fuse inside the tach? just thought i'd ask before i go digging. thanks in advance.
  5. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    we just installed a sunpro on my buddies 350 and it wont work either, weird. its wired right just goes crazy all the time
  6. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    dash lights...
    If your asking where to hook the wire for the light in the tach,you can hook it to the spot provided for that purpose in the fuse box,it's marked with the letters "LPS",and has a spade terminal you can slide a female solderless connector onto..this is for added on gauges,and it also works with the dimmer in the light switch,so it'll dim or brighten like all the other dash lights..:crazy:
  7. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    thats amazing info. im gonna have to remember that one
  8. k5 bray
    Nov 29, 2004
    18
    Cypress TX
    Thats exactly what i needed to know. Thanks
