tach is in...some ?!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Jun 3, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    500 idle
    i never go past 2.5k on the road...i have to ram the pedal to get it even close to 3k
    rollin down the road ill be doin mabye 1.7k
    is this good, bad,?
  2. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    Here's my info for comparison purposes...not sure it's much help though given we're running different setups, tires (31s), etc. 500 does seem low, but don't take my word for it...I know just enough to be dangerous! /forums/images/graemlins/grin.gif
    Idle...650ish
    At 65mph...2700ish
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,090
    489
    Grand Rapids area
    Did you get a tach for a V-10 or V-12?
    /forums/images/graemlins/eek.gif
    I assume your tach signal comes from the tach terminal on the distributor. Where do you get your power and ground? What kind of tach is it? If it is a factory tach, it probably has bad resistors.
  4. swampblazer
    swampblazer Registered Member
    Mar 31, 2003
    49
    mass, u.s.
    that seems kind of strange, what about when you first crank it, where is it at, mine is around 1000 than goes down to 650ish, what about in gear? etc... what about gears, tire size
    luke
  5. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    In idle I run about 600 rpm, going down the freeway with 65 mph in OD I run about 1900 rpm.
  6. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    mine is a supersun tach 2 and mine is around 5-600 at idle and usually around 2000 or a little below criusin around 40-50 id say.
  7. tecton
    Dec 1, 2002
    1,553
    WV
    33 tires
    sun somethnig tach...lil thing for 30$
    342 gears
    when i first start it and it wont kick down it sits about 1k....prob need to turn my idle up some tho cause its startin to want to die
  8. BlazinRojo
    BlazinRojo 1/2 ton status
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    i run 600 idle. With all my weight on the pedal, it shifts from 1st to 2nd at 5000 at 40 mph. 2nd to 3rd happens at 4800 and 70 mph
  9. tecton
    Dec 1, 2002
    1,553
    WV
    i cant get up that high...
    seems most of my power is in the 2-3k range
    this is why im thinkin gearing to 4.10
  10. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Idle seems a bit low, mine idles at 600ish give or take. Those RPMs seem about right, I have the same setup as you drivetrain wise. Im sure you can get it past 2500 /forums/images/graemlins/grin.gif I know mine goes around 4500 when I lay in to her /forums/images/graemlins/thumb.gif
  11. tecton
    Dec 1, 2002
    1,553
    WV
    i lost power with glasspacks and wider tires
    thinking of switching to flow50's to get some power back
    mabye a cold air intake...if those two dont help alot ill wind up re-gearing
  12. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    With 32.4" tall tires, in third gear (direct drive), and with 3.42 gears you should be turning 2,000rpm and going 55mph.
  13. tecton
    Dec 1, 2002
    1,553
    WV
    you forget that k5's are like open trashbags when it comes to awerodnamics....when its not windy...ill be doin 75 and not be able to hear the motor..., somedays i struggle to do 65
  14. tecton
    Dec 1, 2002
    1,553
    WV
    you forget that k5's are like open trashbags when it comes to areodynamics....when its not windy...ill be doin 75 and not be able to hear the motor..., somedays i struggle to do 65
  15. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    I know, my truck has barn door aerodynamics as well. I have 2.73 gears to make it that much more enjoyable with the 700R4. With my mud tires on at 35mph the stereo and wind noise disappear. I have no floor covering, no headliner, just a bench seat so it gets mighty noisey in there.
    However, math doesn't lie. When the torque converter locks up you'll be spinning around 2000rpm at that speed.
