tach light
Discussion in 'The Garage' started by CHEVY 4WD, Aug 23, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    When you hook up a tach and you got it pluged up except for the light(so you can see it at night) where do you put that wire in at btw It should be able to be turned off right?
  2. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i dont understand your question. thers should be a red(ignition/accesory) back (ground) Blue (light, i think) Green (tach, i think) the red wire should only get juice when the truck is on. the blue, only when your headlights are on.
    did that answer anything /forums/images/icons/confused.gif
  3. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    my question is where do i put the wire in for when the lights are on
  4. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    nevermind
  5. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Use a test light to find a spot in your fuse box that only has power when your headlights are on. Hook into that, so when your dash lights come on, your tach light comes on.
  6. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    My '83 Shortbox has a special plug just for that on the fuse panel. So you don't have to jab a wire in along with a fuse.
  7. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    I tapped a front marker light.
  8. A&P
    A&P Registered Member
    Dec 3, 2001
    88
    San Antonio, Texas
    Under the dash, at the back of your headlight switch, there is something like 5 wired coming out of it. Just use the volt meter to find out which one is hot only when the instrument lights are on. Then get on of those cool little clampable splice thingy's (technical term) and splice the positive light wire into it. It will then turn on when you turn your lights on, and will also dim with your instrument lights. That's how I did mine, and havent had any problems. I also wired my mechanical gauge cluster this way. The additional load did not create any problems with early fuse burnout.
    Just my $.02 /forums/images/icons/wink.gif
