Tach Mounting Positions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jc71355, Jun 19, 2002.
  1. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I want to put a tach in my blazer but i don't know where to put it. I don't want to drill into the dash pad if i can keep from it. I thought about putting it on the column but the one part moves and the part that doesn't i don't believe has enough clearance. Not to mention that this is a PIA to get to. So, anyone got any ideas/pictures. I will probably get the smaller 3-3/4.
    Thanks for the idea's.
    James
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Well this is on the dash, but as youve found theres not too many places to put it.
    Tach pic.
  3. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I plan to get an 5" tach and install in the factory fuel guage spot then get the small factory fuel guage.I like all my stuff hidden and as theft proof as I can.I run topless and half doors.
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Mine is on the column...blocking the right turn signal light, but i have a 4 speed truck. There is no rotating part of my column and there's no shifter to work around either.
    I've seen them mounted on the 'A' pillar though, that would be my second choice...
    Rene
  5. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    mines going in the radio hole after i move the cd player to the new console
  6. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    i've got a nice one mounted on the turn signal block thingt on the collum, it sticks there with double sided tape
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Mines mounted to the column with a big pipe clamp. There's only about 1/8" clearance between the tach and the back of the steering wheel, but it works fine. Kinda have to look around it to see the fuel gauge and speedo..No biggy though. /forums/images/icons/cool.gif
  8. Highliner
    Highliner Registered Member
    Oct 20, 2001
    91
    Iowa Park, Texas
    Mine's mounted to the underside of the dash just beneath the ashtray. It faces slightly to the left and up at me. I run an oil pressure and water temp gauge further to the right of it (in front of the 4 wheel drive shifter). It's not a bad spot, fairly easy to see and I constantly glance at the pressure and temp guages anyway.
  9. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    my speedo gear stripped inside the t-case...so i chucked the speedo and replaced it with a 5" monster tach...no speed limits offroad anyway. /forums/images/icons/smirk.gif
  10. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Mines a 5 inch monster tach. I mounted it too the dash so its dosnt block my view of the other guages. If you do moun it to the dash, be sure to use some kinds of backing plate under the dash pad.
  11. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    damn...isnt a 5 inch a little too big for the dash?
    Later
  12. rlhenry
    rlhenry Registered Member
    Mar 6, 2002
    93
    Morenci, AZ
    Mine is on the under side of the dash as well. It's below and just to the left of the ash tray. It's a 2" gauge so that location makes it so someone can still ride in the middle without kicking it. It's also far enough away from the skinny pedal that I don't bump it. I had and '80 truck with a big tach mounted in the same place but it always seemed like it was in the way so a big tach doesn't fit well in that location.
  13. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    What about mounting it on the windsheild pillar in the corner like the ricers do? I have actually seen this on a K5 and it looked pretty sweet.
  14. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I removed the driver's side A/C vent and installed a small tach there.
  15. 85 Shortbox
    85 Shortbox 1/2 ton status
    Jan 24, 2002
    138
    Grandville, Mi
    What about removing the whole ashtray assembly and mounting one their. Or just pull the ashtray itself out and put a small one inside it. That way you could flip it up for concealment.
  16. MTPockets
    Feb 19, 2000
    502
    the 5" tach is a nice tight fit into the stock dash panel.
    the ashtray is where my air/fuel ratio guage is...just flip it down to fine tune the fi system.
  17. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    I have thought about Mounting it to the A-pillar but i'm not fond of drilling into it. I have allready lost one truck cab to rust and i don't want to have to worry about another one rusting out. This maybe a dumb question but is that plastic trim piece on the a-pillar strong enough to hold a smaller tach? I might try to mount it to one of the bolts that holds the dashpad on but that would take some brackets to make work. Thanks for the idea's Keep them coming.
    James
  18. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    pureinsanity's tach is a 5 inch and i mounted mine on the dash where his is. Fits fine
  19. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    Well in my case I have a multi color display which just looks too cool to place tucked away so I mounted it on the dash in the center of the truck right where the dash goes up over the stock display. It's highly visable and dosn't block my view when I'm wheel'in /forums/images/icons/cool.gif
  20. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    The biggest problem w/ putting it anywhere on the post is that you will lose some visibility. Where mine is I dont lose any of my view. The area it covers up from view is on the hood anyway. So I dont lose anything in front or to the side. When you go to install your tach, put it on the post, then put it where mine is and youll see the difference. No to mention it is right there in view, w/ out having to look away from the road or trail.
