tach mounts
Discussion in 'The Garage' started by st08x, Feb 2, 2003.
  1. st08x
    st08x Registered Member
    Oct 17, 2002
    84
    Texas
    i'm putting in a tachometer next week and i was deciding where i should mount it. a friend of mine has it tied to his steering column. where else would be a good mounting place?
    My K-5
  2. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I like them in the corrner of the dash appiler and windsheild makes for a nice view and you can still see the road/trail
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I've got mine on the dash in line with the pillar. It's a good spot. Drilled two holes in my dash /forums/images/graemlins/frown.gif and mounted it there. Out of line of sight, yet still visible with a quick glance. See it here.
  4. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I prefer it towards the center right where the dash drops off. Right here.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I actually mounted mine on the floor next to the tcase shifter. I like it where it is, but most people probably won't. Another reason I have in mounted there is because my tranny temp gauge is right there too, so I used dash light wire for the tcase to back light my tranny gauge and my tach. Not to mention it was easy to run the wires for the senders under the truck to the MSD box on my firewall and my sender for the tranny temp.
    The nice thing about the 2 gauges together is if I look at the tach I also see and am aware of my trans temp and vice versa. Not to mention the tcase shifter location.
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I am partial to the factory setup.
    Easy to see and out of the way. Now the small gas guage gets overlooked once in a while but I always carry 5 extra gallons in the back anyway /forums/images/graemlins/thumb.gif
  7. st08x
    Oct 17, 2002
    84
    Texas
    thanks a lot guys. i think i'm going with the center of the dash right where it curves down and angle it towards me. I also have a hole in my dash right over where a speaker should go. that way i can just run the wires through there and not make another hole.
    My K-5
  8. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Hey Kenny
    is that swap for the Factory tach a pain to put in? I just got one from Redfrog heres the info I have so far what do you think? Right here
    I'm running a 83K5 with mallory ign.
    Eric
  9. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    My tach is next to the A-piller. for me it's great. But pretty soon I'll have the factory setup.
    Eric
  10. kennyw
    Jun 9, 2002
    13,223
    94
    Very easy deal to put in. With a complete housing from the factory you unplug the old one and plug in the new one. Run 3 wires for the tach (power, ground, and tach signal) with the seperate harness.
  11. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    Cool thanks Kenny
    Did you see the stuff? I was thinking of using the speedo with the trip meter. I need to ask Redfrog what year that stuff came out of I guess.
