Tach on column pics
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rob 85K5, Mar 2, 2000.
  1. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    I just re-installed some editing software so hopefully these pics will work this time.
    This on shows how the tach is mounted and the wire run down the column.
    Rob 85K5
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  2. Rob 85K5
    1,487
    Pensacola, Florida
    One more pic from the driver's seat, it blocks the 2 big gauges a little but its not bad unless you're hot rodding it.
    Rob 85K5
  3. Rob 85K5
    1,487
    Pensacola, Florida
    and another on from the other side of the column of the mount and cable run.
    Rob 85K5
  4. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    WHERE DID YOU GET THE TACH! That's great.
  5. Captkaos
    Captkaos 1/2 ton status
    198
    Birmingham, AL
  6. Rob 85K5
    1,487
    Pensacola, Florida
    Re: Steering wheel?
    The tach came from the dealer, it might be in the GM performance parts catalog. The steering wheel came off a pick-up 88 and up til air bags were standard. it bolts right on. You can find some cool ones from z-24 cavaliers that will bolt on also.
    Rob 85K5
  7. **b**
    **b** 1/2 ton status
    279
    KIllington, VT.
    i just fitted one on my 87
    the tac you have there is sweet
    but kinda big ya think??
    i'd suggest installing it into the dash?
    i put a sun super tac
    on mine by using a steel raditor hose type clamp
    i painted the clamp to match the column.
    i have it mounted so that when in park it is almost under the wheel when i shift into drive it moves with the column.
    with all other gauges in view aside from the right directional / but we dont use them in Boston..
    did it all with one hand because iam still in this god dam cast..
  8. Captkaos
    198
    Birmingham, AL
  9. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Re: Steering wheel?
    That is the same way I have mine mounted. Well I use a large hose clamp around the column, but it is mounted in the same exact spot on my tilt column. The wires run the same way. Coincidence?
