Tach Placement UPDATE: I Got the Tach but have 1 Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by daleearnhardt01, Mar 19, 2003.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    I want to put a tach in the truck. I was thinking of mounting it on the A pillar. What are yalls suggestions for mounting it there (how, why I shouldnt mount it there). Heres what I want to put there Tach
  2. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    Re: Tach Placement
    dead center on the steering column..between speedo and gas gauge. I've seen a lot of 'em there.
  3. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Re: Tach Placement
    Wont it rotate down with the shifter? My friend has it like that in his 87. I havent really looked to see exactly where on the column its mounted
  4. 4x4dreamer
    Jul 8, 2002
    874
    St. Petersburg, FL
    Re: Tach Placement
    I think they mount it forward of the shifter. I plan on moving the gas gauge to a small gauge, then putting a tach (digital of course) where the gas gauge was.
  5. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    Re: Tach Placement
    I had my monster tach mounted on the piller with the bottom of the tach just touching the top of the dashpad. Then I used a piece of shock boot to cover up the mounting bracket. The wires all tucked between the dashpad and the inside of the cab. Lokked great and I never had any problems with it coming loose or shaking . /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
  6. Hustler
    Hustler 1/2 ton status
    May 14, 2001
    326
    St. Peters, MO
    Re: Tach Placement
    I have a monster tach on my piller now and I haven't had a problem with it.
  7. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Re: Tach Placement
    Cool im glad it seems to work out there but do yall just attach to the plastic or go into the metal?
  8. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Re: Tach Placement
    Centered on the column.
  9. Hustler
    May 14, 2001
    326
    St. Peters, MO
    Re: Tach Placement
    I used the screw that holds the plastic piece up there and I would guess that it goes into the metal. I did screw in another screw into the plastic to it would be steady. So far, it has held up good. I haven't taken it off road other then going on old muddy logging roads.
  10. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Re: Tach Placement
    Now I just gotta see where to get the best price on the tach
  11. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Re: Tach Placement
    Does anybody know the difference between the Autometer Sport Comp and Autogage tachs? For the one I want I dont see a difference between the two except 50 bucks. The prices seem to be the same at Jegs and Summitt. /forums/images/graemlins/shocked.gif
  12. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Re: Tach Placement
    i mounted mine on the steering column. it's placed so that when i'm in drive it's just below the speedometer.
  13. Hustler
    May 14, 2001
    326
    St. Peters, MO
    Re: Tach Placement
    The difference between the Autometer Sport Comp and Autogage tachs is very little. Autometer builds both, but the Autometer model is for racing, major off road use. the Autogage is made with cheaper parts. I have used the Autogage for dirt track racing, drag racing and that is the model I have in my Jimmy now. For the money, I would say get the Autogage, unless you have the money to get the Autometer Sport Comp.
  14. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Re: Tach Placement
    Alright now I need to see what yalls opinion is on a shiftlight. Can the light be moved to the right side of the tach? Heres a poll.
  15. Hustler
    May 14, 2001
    326
    St. Peters, MO
    Re: Tach Placement
    I say yes. Yes you can move it. Mine is on the right side at the bottom of the tach.
  16. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Re: Tach Placement
    Top of dash just to the right of the gauge panel, angled to face driver.
  17. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Re: Tach Placement
    Can the shfit light totally come off? I mean for 10 bucks more Ill get the one with the light and If I dont like it ill take it off.
  18. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Re: Tach Placement
    My tach for time being is next to the A pillar. And for me I don't see the need for a shift light unless you plan on mud/sand drags. I can see the red line on my tach just fine. Now when I put my OEM tach in it won't be as easy to see, At lest right noe I say that after I get it in I mite change my mind.
    Eric
  19. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    Re: Tach Placement
    you can see my tach in the pic, its fixed to the a piller but just on the dash. The dash wouldnt hold the screws. I like it there personally
  20. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Re: Tach Placement
    in my blazer the tach is just to the right of the gauge panel on top of the dash pad and I routed the wires down through the dash pad and put a nice grommet around the wires in the hole. Looks nice. In my daily driver it is mounted to the dash just to the drivers side of the gas tank selector switch. Out of the way but easy to see.
