TACH question, is there a difference in carb/tbi tachs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jjlaughner, Jan 3, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Seems like I remember seeing something about not wiring your tach into the normal places on a TBI because it could short things out?
    Is there a wire in the factory wiring harness you can tap into behind the dash for factory tachs or is it a completely different harness for vehicles with factory tachs?
    Anyone have a wiring diagram for any of the above?
    Thanks, Jeremiah
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    There is a wire off the coil that is for tach signal, IIRC it is a white wire, this is for TBI trucks. If you have an earlier truck with the large HEI dist, then there is a place in the dist cap for tach signal wire.
  3. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I'll have to check, my truck I know has the remote HEI coil. I dont remember seeing a spot on the cap during the last tune up. There are a couple connectors on my firewall that have never had anything connected to them and one or two small wires with caps around the injection harness that I have always wondered what they where for. Maybe I'll get some closeup pics this weekend.
    J
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Use the white wire that comes off the 4 wire connector on the coil. That is the only place to hook it up.
    That is the factory hookup.
    Its the wire I wired my aftermarket tach to it works fine.
  5. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    I did the same as thunder hooked it into the white "test" hookup off of the coil. Its worked flawlessly for the month I've had it in there.
    I still lhave to find a permanent place for the tach. I currently have it tie straped to the steering column. I don't want to put it on the dash until the Jimmy looks a little meaner( tires bigger than 235/75r15's) Where does everyboy else have them?
