Tach Wiring Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87K54WD, Oct 29, 2001.
  1. 87K54WD
    87K54WD 1/2 ton status
    Mar 23, 2000
    105
    Texas
    Does anyone know if autopart stores sell the end connector that will fit in the fuse box under the left side of the dash. Also, does anyone know if one of those empty slots taps into the lights (white wire I believe) (when the lights are turned on ... so the tach will light up as well)? Thanks.
  2. Alex
    Alex Registered Member
    Jun 19, 2001
    78
    Northern California
    87K54WD, get yourself a test light at the your favorite auto store. They’re inexpensive. Then, check which empty slot has power when you turn the lights on. Then, yes, you can buy the connectors. However, they’re a tad different. I tapped into my fuse box (on my Toyo) for back up lights and used a round female connector. It’s in there snug and I can still pull it out if I need to… (that's what she said…).
    <P ID="edit"><FONT class="small">Edited by Alex on 10/29/01 08:53 AM.</FONT></P>
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Ya might wanna look into a wire tap connector or a "Scotchlock" type connector to splice into a existing instrument panel light wire. I believe the wire you will need is grey...white is for dome and courtesy lights.....at least on my '74. I'm not sure there would be a good place at the fuse box to tap into for the light. Autozone etc. have the splice in type connectors.
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  4. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    on my 90 I just used spade connectors
    and on the fuse block there is a red ACC slot for the power and a green lamp slot for the light wire and there was a wire hanging off my coil that I used another spade connector on then just grounded it behind the dash
    I'm Back BACK IN BLACK
    <a target="_blank" href=http://photos.yahoo.com/jwileywilliamson>photos.yahoo.com/jwileywilliamson</a>
