  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    how do i put a tach in my blazer. its an automatic 700r4, and a 350.........................
    high
  2. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Are you looking for a stock or aftermarket tach?
    - Alan
    '82 K10 Suburban Silverado (AKA U.S.S. Nimitz)
  3. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    aftermarket
    high
  4. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    I don't know what year you have, but the wiring of most aftermarket tachs is similar. +12V constant (batt), switched +12V, ground and a tach signal. The tach signal terminal is found on an HEI distributor on the cap itself (will be marked "tach") or on the ECM somewhere, seeing that you have a '91 (just looked at the profile), that could be a possibility, too. I'd check out the distributor first, though, before the kick panels start flying. Hope that helps, as I'm assuming that's the info your looking for?
    - Alan
    '82 K10 Suburban Silverado (AKA U.S.S. Nimitz)&lt;P ID="edit"&gt;&lt;FONT class="small"&gt;&lt;EM&gt;Edited by Burbinator on 09/17/01 06:01 PM.&lt;/EM&gt;&lt;/FONT&gt;&lt;/P&gt;<P ID="edit"><FONT class="small">Edited by Burbinator on 09/18/01 11:15 AM.</FONT></P>
