Tach
Discussion in '1982-Present GM Diesel' started by JORGE, Apr 1, 2002.
  1. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    I have installed the isspro tach and a isspro mechanical oil pressure gauge,in these days.The tach is allowed in the place for the optional clock,(Mine is a Custom Deluxe without clock).The Isspro tach is great,it works fine.Is a good set.
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Where did you get them from? I could use both a tach and an oil pressure guage.
  3. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    Where did you connect the tachometer? At the alternator?
  4. JORGE
    Jan 10, 2001
    213
    I got it in Internet www.isspro.com The set was in Spain in 3 days!
    This is the theme.With the isspro tach,is not necessary to conect nothing to the alternator,with the riske to damage it.Isspro has set wich has a specific tach for the 6.2 engine,you only need to attach with glue two little magnets to the engine pulley at 180º distance.And then attch a magnet sensor in one of the front oil pan lugs,for detect the magnets when the pulley is in motion.Is a very easy installation,and you don,t need to open the alternator.
  5. 6.2L Jimmy
    6.2L Jimmy 1/2 ton status
    Jan 2, 2002
    164
    Montreal,Quebec
    Hi,
    Would you have the part number for the 6.2L tach?
    Mike
  6. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    That sounds good, I have a tachometer attached at the generator, but everything does not show the correct number of rpm’s... I’m looking for a sender, which one fastens to an injection line and so that gives the impulse to the tachometer.
    Muchos saludos del emigrado catalán.
  7. JORGE
    Jan 10, 2001
    213
    The Isspro tach part number is R8503 you also need the sensor magnet kit R8900. In the Isspro page you can see pictures.
    Who is "El emigrado Catalan"?Rene,you are german,no?Do you have some Catalan friend?
  8. 6.2L Jimmy
    Jan 2, 2002
    164
    Montreal,Quebec
    Hi
    Thanks for the part numbers Jorge
    MIKE
  9. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    My mother is Spaniard and I was born in Barcelona. I have both the Spanish and the German nationality. For the moment my parents lives in Tarragone.
    The tachometer I meaned, gives it from EQUE but only with digital display. That looks like ***** in the classical instrument panel.
  10. JORGE
    Jan 10, 2001
    213
    Well, I,m from the Basque Country. Is a great surprise,at the moment i was the only from here in the forum,well i think the only stranger in the forum.My english is very bad,but in this forum i feel to me like in my own home,with the rest of the Blazer boys.
    Ok, a digital tach is not for a Gm truck.Please remove it ,throw it away,and install a good diesel tach.
  11. JORGE
    Jan 10, 2001
    213
    Hello 6.2L Jimmy,
    You don,t need to give to me the thanks.If you need more details,please let me know.
  12. 6.2L Jimmy
    Jan 2, 2002
    164
    Montreal,Quebec
    Will do .
    Thanks again.
    Mike
