TACHOMETER FOR THE 6.2
Discussion in '1982-Present GM Diesel' started by JORGE, May 4, 2001.
  1. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    Somebody has installed a tachometer in his Diesel Blazer?
    Is there some kind of tachometer for the hollow in the gauge panel,under the voltmeter?I,ve heard about the Borg Warner.
    I should need to take the connection in the alternator,correct?
  2. NewK5Guy
    NewK5Guy 1/2 ton status
    Mar 2, 2001
    556
    Alexandria, VA
    Autometer sells a diesel specific tachometer. With a converter from Dakota Digital(www.dakotadigital.com, $95), you can use any gas engine tach.
  3. JORGE
    Jan 10, 2001
    213
    Yes,i,ve been looking the Dakota,s page.I suppouse the blazer alternator hasn,t W therminal.Should be neccesary the Fly-wheell adapter?Thanks.
  4. NewK5Guy
    Mar 2, 2001
    556
    Alexandria, VA
    You can use a flywheel adapter IF you can fine one. They are few and far between. That's how the stock 6.2 tach worked and that option was very rare. Only a handful of 6.2 owners have it. I don't know if the 6.2 alternator has that W-terminal that the Dakota Digital adapter needs. I'd find out exactly what year alternator is on your 6.2 and maybe ask a dealer. I know you probably don't have a dealer over there, so maybe someone here could help. Go to The Diesel Page(www.62-65dieselpage.com) and go into the Light Truck forum and ask. Someone there is bound to know.
  5. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    I put a DATCON tach in my 6.2 mounted it to the moving part of the column, so i rotates into acton when in drive. It is small and does not get in the way of anything. It is driven off of the alternator. You have to take the alternator apart and attach a wire to the diode trio. It is very easy to do, then just run that wire into the tach. Let me know if you need any more help. TORI
    '89 K5..... 4" Tuff Country EZ Ride. 33's and a "Colorado K5.com" sticker. This site rocks!!
    <A target="_blank" HREF=http://www.tori89k5.coloradok5.com>http://www.tori89k5.coloradok5.com</A>
  6. MasterChief
    MasterChief Newbie
    Jun 9, 2001
    3
    Bahrain, Arabian Gulf
    Where can I find the DATCON Tach you mentioned? I had a tach from JC Whitney, but it broke and it attached to the alt diodes just as you said, but they no longer sell that model, do you know a source for your tach?
    Jerry
  7. tori89k5
    Apr 12, 2001
    946
    I WILL LOOK FOR THEIR INFORMATION WHEN I GET HOME, AND LET YOU KNOW.
    TORI
    New '90 K5 sitting in my driveway !!! YIPPPIEE !!
  8. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    Isspro makes a magnetic tac with 2 little magnets you mount to the harmonic balancer. I got mine for $133 from Diesel Injection Service - www.dieselpage.com. I haven't installed mine yet but I imagine a magnetic tac would be the most accurate way to go. I think its also easier to install cause I've heard you have to partialy dissasemble the alternator to install an alternator tac.
  9. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I have an in dash GM tach which I plan to use. Has anyone looked at the gas tach signal
    on a scope? I was thinking of getting the vacuum pump which has the ESS
    module on it and maybe building a proper circuit to drive the tach using the
    ESS signal.
    I looked at my '85 diesel wiring schematic in the factory manual and saw no
    references to a diesel tach circuit in that year.
    SteveB
  10. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,038
    1,107
    Dallas
    Gale Banks Engineering makes and entirely bolt on Tach kit for the 6.2L. Banks part # 64003. Typically $245.
    David Oliver
    '85 'burban - 6.2L J NA
    5.5"lift, 35"BFGs
    *B&B 6.2L TD and beefed T-700 coming soon*
  11. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Just finished upp instaling one of these yesterday. Took a total of 3 hours. Basicly it's bending a bracket to go from one of the front oil-pan bolts, around the flywheel? and infront of the harmonic balancer. On the end of the bracket is a reader, that reads each time a magnet flies by. The two magnets are to be epoxy-glued to the balancer 180 dg apart. I used my sandblaster nozle and took the surface down to the bare metal first. A couple of raps with grindingpaper on the magnets.Then I mixed upp the epoxy and made big pockets of the glue for the magnet to sit in. The glue should ooze out around the magnet when installed.
    Tested it today after letting it dry for almost 20 hours, and there it was !!
    I will document this with pictures, and put it up on my web-page sometime before the weekend.
    <font color=red><a target="_blank" href=http://www.espen88k5.alloffroad.com>www.espen88k5.alloffroad.com</a></font color=red>
  12. jarednbonie
    jarednbonie Registered Member
    Jul 18, 2001
    9
    I need to install a tach as well in my Sub. Meanwhile though, can anyone give me an idea of how high I'm revving? I have an '87 Sub w/ 6.2. I'm not sure what gears I have in the rear end (which makes this more difficult). I've heard though that 3.42s are real common. I put a TH400 tranny in it and I have 35" BFG muds. The engine sounds pretty revv'd at 65mph, but it's hard to tell with loud tires, etc. I'm new to the diesel too, so I'm not sure if it's revving too high, or just fine. Can anyone with a similar setup give me an approximation of rpms at these speeds?
    '87 Suburban, 6.2, 35"s
  13. Espen88k5
    Feb 19, 2000
    981
    Norway
    I'' seeing 2 000 at 45 in 3'rd. In OD it goes down to almost 1400. I would guess 2500 or 3000 should be right ?!
    Maybe I helped some
