Tachometer on a 6.2 diesel
Discussion in '1982-Present GM Diesel' started by fcfred, Aug 19, 2003.
  1. fcfred
    fcfred Registered Member
    Jun 5, 2001
    7
    Portland, OR
    How do I put a Tachometer on my 6.2 diesel in my CUCV
  2. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    521
    Terre Haute IN
    The best way is a magnetic crank sensor setup. One or two companies sell them, about $250. If I ever remember the name of the company I will let you know.
  3. rugger03
    rugger03 1/2 ton status Premium Member
    May 14, 2000
    829
    around
    Isspro makes a magnetic pick up which cost about 50 bucks, It uses magnets glued to your balancer to generate a signal for the tach. I think you can get the whole setup (pick up and gauge) for about $150 from various different vendors.
    cheers, rugger
    Edited because my illiterate stunt double replied to a post with asking me first
  4. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I installed one on my brothers 6.2 that is made by Stewart-Warner. Car-Quest carries them and the tach has a nice large 3 3/8 diameter face. The sensor picks up the teeth on the ring gear. Had to weld up the dust cover a little so the jam nut would have a smooth mounting surface is all.
    Diesel tach #CPS 80588 +/-$120
    Mag pickup #CPS 80816 +/-$35
    Has a 0-3500 rpm range.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,161
    Sacramento, CA
    I just installed the TINYTACH $65 plus shipping.
    Total under $100 and it also records hours of use.
    I like it.
    I will try and find the link for you. /forums/images/graemlins/thumb.gif
  6. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
  7. Txstruck
    Txstruck Registered Member
    May 25, 2002
    87
    Seagoville, Texas
    I can get the 3 1/2" stewart-warner 0-3500 tach for $98 brand new at work. (Oreillys Warehouse) It has the chrome face ring and all. /forums/images/graemlins/truck.gif
