Tachometer ????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LA Bogger, Mar 3, 2001.
  1. LA Bogger
    LA Bogger 1/2 ton status
    May 19, 2000
    192
    Robins AFB, Georgia, USA
    Those of you that don't have a factory tach... Where did you mount your tach???
    Thanks in advance!!
    Eat More Mud!!!
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I've got mine on the dash up to the left. I will put in a factory tach. in some day though.
    Lost? i'm not lost i'm just disorienated
  3. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> I have mine on the hump over the gauge panel near the right corner ........... you can see on this pic.
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
  4. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    Mine is on the column. It is a nice setup, but I will eventually put in factory, or factory looking in dash tach.
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    On the column. No holes to drill that way.
    '73 K5
    Chevy good...Ford bad
  6. LA Bogger
    May 19, 2000
    192
    How did you attach your tach on the hump? Look cool...!!!
    Eat More Mud!!!!!
  7. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    On my K30, I use a small Sun tach. It is mounted on the instrument cluster bezel over the steering column.
  8. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    It is an Autometer tach that has a curved bottom and is attached by zip-ties. It turns when you put it in gear. I will try to borrow a digital camera and get a pic of it. I like that it is right there next to the speedo, next best thing to a factory tach, IMO.
