tachometer
Discussion in 'The Garage' started by Janitorjim8, Nov 20, 2005.
  1. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    So i've had a Sunpro tach for a while... I'm going to hook it up soon. I think i've lost the directions, any one here installed one and have any tips or procedures.. i know that the white wire splices into the white wire going from the distributor to the firewall... or am i wrong there too lol. By the way its a 90 k5 with a 350
  2. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Is it HEI? If it is it has a tach port on it where you just plug it in. Then you gotta run a power, power for the light and a ground. Its very easy.
  3. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Sorry just noticed the year model in your post. Mines carbed but seems like it would still be the same on the dizzy.
  4. Janitorjim8
    Feb 21, 2005
    215
    Illinois
    hunterguy- where is this tach port, it is hei.
  5. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    On the right side of your distributr is a wire. Close to this wire, it says "tach" and there is a terminal which you can plug into.
    You can download the sunpro instructions somewhere, because I did it a few years ago when someone gave me a free sunpro tach.
  6. Janitorjim8
    Feb 21, 2005
    215
    Illinois
    thank you very much
  7. gmcjimmy90
    gmcjimmy90 Registered Member
    Jul 3, 2005
    76
    arkansas
    it should have an external coil and you need to hook it up on the wire that is coming off of it (the one not hooked up to anything else).
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I thought the white wire is for your lights and the green wire is for the signal....
  9. keifer
    keifer Registered Member
    Nov 1, 2005
    16
    MD-Phoenix someday
    bingo
  10. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    On the external HEI you want to hook the green wire on the tach to the white wire on the - side of the coil. Red to ignition on power. White to parking lights. Black to ground.
  11. Janitorjim8
    Feb 21, 2005
    215
    Illinois
    jebsr how do i tell which side is the negative side of the coil
  12. Janitorjim8
    Feb 21, 2005
    215
    Illinois
    jebsr how do i tell which side is negative side of the coil?
  13. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    On the external coil it is not marked, but it is the white wire. I can get a pic of mine if it would help. Sorry it took so long, been out of town for turkeyday.
