Tack weld nut
Discussion in 'The Garage' started by rcamacho, Oct 16, 2005.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Folks, I'm considering tack welding the 3/8" nuts that join the stock 208 skid plate to the x-member. Any suggestions on technique other than keeping the heat low and tap cleaning the threads afterwards?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I prefer to weld with the bolt in place and keep the heat as low as I feel safe for penetration.
  3. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    ding, ding, ding... we have a winner! :D
  4. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    I agree!
  5. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    HEE HEEE HEE HE SAID PENETRATION!!!!! :haha:
    sorry few killians and everything is funny now :bow:
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I'm curious, why would you want to do that?
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Maybe he is boxing the frame. Its a neccessity in that case. I will likely do something similar since I'm heavily considering boxing the S10s frame.
  8. rcamacho
    Jul 1, 2004
    1,324
    WA
    I have to drop the xmember shortly to eliminate the trans case drop and convert to a CV shaft. Seems to me that If I tack the nuts it will save the usual gymnastics with two wrenches.
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Better, if you have the option, is to weld in a threaded piece of steel of at least the same thickness as the height of the nuts, but a little longer in at least one direction. I put anti-sieze on the threads of the sacrificial bolts I use to hold the "nut" in place, and weld it away from the threaded hole. Then you can turn the heat up and not be as likely to mung the threads.
  10. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Ah, great ideas. Thanks!
