Tackling p/u truck sliders...
Discussion in 'The Garage' started by pismorat, Apr 9, 2005.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    Alright, I am tired of fearing smashing up my cab with rocks, so I designed some sliders and am going to start on them tomorrow. :hack: :weld: :grind: I am only going to protect the cab for now. I plan on using 2x2x.120" square tubing for the most part. Any tips I should know prior to this?? I'll keep you posted on progress. :truck:
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I look forward to seeing what you do. I worry about my saddle tanks more than my body, already put one of them right on a rock.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you smack down hard on the 2x2x.120 you will dent the tube and you might also bend it if you hit hard enough. 2x2 is also kinda narrow. I would recommend 2x3x.188 as the minimum for sliders.
    My sliders are 2 pieces of 1.5x1.5x.250 welded side by side to get 1.5x3" It is heavier then most sliders but they aren't going to bend and I netted another 1/2" of clearence over most people's sliders.
    Harley
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Mine are made from 4" x 2" x .250 tubing. I argee, .188 wall should be the minimum.
  5. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    In the spirit of saving weight and being light, I smash the cab! :screwy: Stock rockers slide pretty good hehe
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i used 2x3 .125 wall tube to replace my rusted rocker, i wish i would have gone with 3x3, i have more clearance, but my tank hangs below the rocker.
    id like to see how you braced them
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    TJ, ever thought about mounting your stock tank to the bulkhead of the bed? a little reinforcement, and some easy modification to the filler tube, and it should work great.
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    actually i have thought about making a fuel cell to fit under the toolbox, but that is where i plan to put the onboardair tank if i ever get around to that. if i put it behind the tool box, then its taking up bed space. and yes i still use my truck as a truck.
  9. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i think the easiest thing to do about the saddle tanks is to remove the 8 bolts holding the bed on, and put a blazer tank in between the fuel rails in front of the diff
    my body lift made it easier for the fill routing, i just fill it in the wheel well
  10. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    are you just building them under the cab or are you going to go under the box a bit too. it'll be good to see a set on a truck. Thats one thing i have on my longs list of mods :grin:
