tahoe towing ?
Discussion in 'Tow & Trailer' started by Bhintz, Jun 15, 2004.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    well Im going to me buying a new (used) truck and turning the k5 into a trail truck and I need a dd that will tow the k5 and been looking at some 96-98 tahoes w/ the 350, my question is Ive been looking a some 2 and 4 door ones and will the 2 been able to pull a k5 or will the WB be to small were I need to get the 4 door and will the 350 have enough grunt to pull the 7000lbs ill be pulling
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    96+ tahoe's get the vortech motor. the 5.3 vortech is said to make the same power as the 5.7, and the 5.7 as much as the old 454's did. You can tow with the 2 dr , but ... again, its the whole wheelbase thing. 4dr would be better. 2 door aint great, but douable, get some WD/ sway setup. I think the 4dr tahoes only gain about 1 foot or so in wheelbase anyways.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A 1/2 ton rig is not really enough to be pulling a fully loaded K5 on a trailer. 7500+ lbs should be pulled with a 3/4 or 1 ton rig only.
    In other words, look for a 3/4 ton suburban instead.
  4. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Sorry, some updated info.
    Wheelbase..................2-door: 111.5 inches
    4-door: 117.5 inches
    Overall length.............2-door: 188.5 inches
    4-door: 199.1 inches
    So you can see, there's only a 6" difference between the two. /forums/images/graemlins/smile.gif
    250hp, 335torque in 96+ (5.7)
    200hp/310 torque pre 96.
    Should be plenty. Note however, the truck is only rated to tow 7000lbs- Double check those numbers yourself.
  5. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I would have to agree with Tim on this one.
    A tahoe is fine pulling a bass boat or corvette, but a heavy K5 is really pushing it IMO. The engine may be up to the task but the tranny, rear axle, brakes, and suspension is not likely to be.
    Can you do it, Yes, with a proper weight dist. hitch and sway control. Would I do it?, no.
    Just my .02,
    John
  6. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    A friend of mine has a 98' Tahoe...
    He's pulling a 7000 GVW trailer and a k10 shortbed...
    It has the 350...and it doesn't do to bad...
    It doesn't have an ideal gear for towing (3.42's)...
    so hills can be rough..but it pulls..
  7. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    I would get the 4 door, like others have said with a WD setup and trailer brakes, you'll pull fine. Just go easy. I pull my jeep (about 5000 pounds) with a 98 Z71, and it does just fine.
    I have towed a K20 with a 90 1/2 ton 4x4 sportside, a little to short in my opinion, but it towed great and I had no problem with the tranny, springs, or rear axle and I towed alot with it.
    I would definitely put a big tranny cooler in whatever you buy though if it's an automatic.
  8. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I'm gonna agree with Tim(for once /forums/images/graemlins/wink.gif) on this also.
    I like this quote:
    "Just 'cause you can drive a car with your feet, doesn't mean it's a good phuckin idea!" - Chris Rock
    I'd go with at least a 3/4 ton....
  9. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I tried to tow my 78k10 with my 99 Yukon (I think it's rated for 8000lbs towing) and I was really disapointed. It has a 5.7 vortech and a 4l60e transmission. I don't have a temp gauge, but I could smell the trans burning just driving around on level ground. It took a looong time to accelerate. The trailer was a 7500gvw and it was right at it's limit so that probably didn't help, but If you have a choice I would definitely go with a 3/4 or 1 ton.
