tail gate
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by im_2gr82h8, Oct 11, 2001.
  1. im_2gr82h8
    im_2gr82h8 Registered Member
    Apr 4, 2001
    91
    federal way, washington
    I know this is a stupid question, but i can't figure it out. How do I get teh tailgate off??? I want to take it off to repaint it and have had no luck.
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Well open it up. Unplug the wiring. Unbolt those two rods going to your frame, careful, they're springs under tension. Then put a prop rod under the gate to take the weight, an old axle shaft was a good height for mine (31" 2" lift). Then undo the straps on the sides. Unbolt the four bolts on each hinge on the gate and get a buddy help you pull it off cause its heavy. To be honest I would gut the thing before taking it off to make it lighter and so you dont have to tape things off. Then put in new weatherstrip and undercoat the insides.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  3. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Even I figured that one out myself [​IMG][​IMG]
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    GO BUSH
