Tail gate
Discussion in 'The Garage' started by Z3PR, Apr 11, 2002.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Anyone had the problem of not being able to open your tail gate ??? I rolled the window down, pulled up on the handle, and nothing happened. The handle isn't super stiff, but it's not sloppy loose either.
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Mine you have to push on the passenger side real hard for it to open...I think it just needs to be lubed up inside...Dan
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'll try that in the morning. With my luck, I'll get it open and not be able to get it to stay shut.
  4. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    Sounds very familiar. The metal lever attatched to the back of the handle bends because it's weak and therefore the rod connected to it can't travel far enough to fully pull the release mechanism. it can be bent back, but just bends again. (the "lever" arm should be at a 90 degree angle with the back of the handle) I am planning on reinforcing mine somehow. It helps me too if I push in on the tail gate while opening it.
  5. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    If my memory stills serves me....there is a metal arm inside the gate that prevents the gate from opening when the window is not all the way down. You might have to pop the cover off and take a look at it. Mines gone!
  6. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    Mine won't open unless I grab the two metal rods inside and pull towards the handle. It also won't close all the way even with pushing on it very hard. I think the latter is because the sides ofthe bed are tweaked outwards a bit at the top and need to be straightend and strutted. I'm just going to look for a new tailgate because the window won't roll up and down either.
  7. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    mine i have to lean my whole body into the gate and pull up on it...it wont open unless you push it in real hard..
    Later
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I just got it to open by pushing in on the right side. I opened and closed it a few times, it seems to be working fine now. I still need to soak it with some WD40, but it seems to be working now. Thanks for the help.
  9. SnowNuts
    SnowNuts Registered Member
    Apr 5, 2002
    48
    Detroit ,U.S.A. HOCKEYTOWN
    PB BLASTER...A WHOLE CAN OUTA BE ENUFFF
  10. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ahhaha you guys wanna good story about a tail gate..lol on my k5...(cuase its pretty badly rusted in the rear and side fenders in the rear) lol.me and my dad just wanted t SEE what it would do when we opened it..well..it split in half. yeap..one side fell back..and then the other lol..and there was some horibble rust there..and the rear of the flor panals in the back are shot..they will both need to be replaced..but today im going to look at another 84 k5 (mines 85)..it has no engine or tranny..but the bpdy is suppost to be pretty good..this might be my ticket! ill let you guys no what happens! lol
    bryan-later
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Nice story, that'd been a kodak moment.
  12. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I have a truck gate on my "73 Blazer.I run with no top and no doors.Once in a while during hard wheeling the gate will pop open.Should be solved soon!!!I am not going to tell you how I will fix this.Just wait and see.Brady
  13. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    lol i know...weres that damn camera when you need it!!??..lol..
    well right now we are currently figuring out a SLIGHT room problem here..theres that other blazer i might buy depending on the body condition...and then theres this one i have..now see we live in the suberbs..not the city city..but liek def. not in the counrty...lol and we are getting cramped..with two cars and my dads truck and my blazer, and we havea boat, and then if we got this other blazer o boy! lol..we would have the bout and the blazer in the back yard..we are ganna start to look liek a scrap yard around here befor long! lol
    later-bryan
  14. gotmud?
    gotmud? 1/2 ton status
    Feb 23, 2002
    1,172
    up north
    theres a bolt to the right of the bottum mounting bolt for the handle mechanism that's in a little cut out that you can loosen then tighten to adjust the play in those rods when you open your tailgate pull back on the side latches then move the rods till you get the latches to work with minimal pulling on the handle. might want to spray this bolt a few days ahead of time as i broke mine the first time I did this.
