tail ights work, rear turn indicators and brake lights don't
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Jan 13, 2002.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    tail ights work, rear turn indicators and brake lights don\'t
    Took the truck in for the "test" inspection. Even with a full visual under the hood, they somehow missed the smog pump without a belt! But... my brake lights and rear turn indicators are no longer working. Although, the tail lights work. Where do I even start on this? The front turn indicators do work. Help!
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  2. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    Re: tail ights work, rear turn indicators and brake lights don\'t
    I had/have the same danged problem. I took of my rear light covers and took everything 100% apart and found about 700lbs of dirt, dust and mud. Thinking this may have something to do with it I cleaned it all up and put it back together. By this time I had already checked all the fuses and such but when I checked her I still had the same problem. I just parked the damned thing and have been so busy I haven't messed with it since. If you figure it out you get an A++++. If not I wont hold it against you I've talked with many that have had this same problem and have yet to figure it out. If you do figure it out post it here and e-mail me please.
    [​IMG] ps: I just now noticed you have a '85 gmc jimmy! it was my '85 jimmy that gave me the same b.s. [​IMG]
    coincidence? I don't know!?!?!?!?
    '85 k-5 gmc jimmy 4x4 sierra classic. '84 k-5 gmc jimmy. '70 cuda 440 6 pack executive edition shaker hood, steering column shift.<P ID="edit"><FONT class="small">Edited by speed_deed on 01/13/02 09:31 PM.</FONT></P>
  3. wrath
    wrath 1/2 ton status
    Mar 4, 2001
    182
    Grayling,Michigan
    may seem stupid but did you check your fuse box..check the grounds in the back also.
    70K5 350ci.350/205 "PROJECT 40"BOGGERS" It runs and its clean !!
    <a target="_blank" href=http://communities.msn.com/OurMudToys/the70k5blazer.msnw>http://communities.msn.com/OurMudToys/the70k5blazer.msnw</a>
  4. speed_deed
    Jun 15, 2001
    947
    Valley Center KS
    As for me: "Been there done that got the tee-shirt!" [​IMG]
  5. wrath
    Mar 4, 2001
    182
    Grayling,Michigan
    May not be the same but went thru this on my 70 k5 ..and ended up be a ground in behind the marker light..it is different but you should check your grounds,check your bulbs,the 1157 bulb has tailights on one filament and blinker and brake on the other..hope this helps..electrical sucks!!! good luck
  6. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I don't have the stock taillights in my blazer.I have round ones in the tailgate.But I have had this problem a couple of times.Once it was in the fuse box all of the connections were rusty.Cleaned the fuses and terminals and all was fine.Another time it was in the wireing in the rear.The wires are exposed underneath and tend to get ruinned from weather or mud or snow.Or check for extra wires for a trailer.Mine had trailer wires that were put together with crappy connections.Since the fronts are working it is probally in the wiring in the rear.hope this helps.Brady
    '73Beautiful Disaster
  7. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    Well, good news. I pulled everything apart and cleaned it all. Still wasn't working. Checked the bulb, both filaments were intact. Got out the meter. Found a good ground an hot lead for the tail light. Other wire must be the blinker/brake. Yep. With the meter, I found that wire to toggle hot/cold with the blinkers on. Checked the contacts inside the bulb mount and they were showing to work. Really puzzled. Dug up spare bulb in the glove compartment. Thought, what the hell. Sure enough, it worked! Put it in the other side (it's filaments were intact as well) and it worked there, too. On my way to Walmart now for spare bulbs. Bulb was bad even thought filaments were intact.
    Either I lost them both at once, or I have been without one and didn't notice and finally lost the other. Funny thing, while testing, found out my turn/backup fuse was only 10A when it should have been 15. Getting more of those, too, as it blew during my testing!
    Thanks for the responses!
    Brian
  8. speed_deed
    Jun 15, 2001
    947
    Valley Center KS
    CONGRATULATIONS!! I HOPE LIKE THUNDER THAT IT WILL WORK FOR ME! I"LL BE OUTSIDE AS SOON AS THE SUN COMES UP IN THE MORNING! THANKS
  9. wrath
    Mar 4, 2001
    182
    Grayling,Michigan
    Congrats!!! glad to hear it worked out for ya.sometimes it can be a nitemare
  10. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    They always seem to go out in twos... least mine do... both times they burnt out it was at the same time (I had no clue because I see them lit but didn't know the brake part was dead)... lucky I had a nice policeman stop me both times to point this out! [​IMG]
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>
    Suck Fumes Ford Boy
    Stop Global Whining
    I'm in shape.... round is a shape......
  11. bking
    bking 1/2 ton status
    Jan 4, 2001
    176
    Alaska /Here from Ireland in Dec 2000
    What about front turn sigs (in behind the grille) are these double filament too?
  12. Chaz316
    Chaz316 1/2 ton status
    Jul 25, 2001
    224
    Georgia
    I had a similar problem with my 73 and it turned out to be a wire had worked loose on the steering column behind the dash. I noticed it when I was changing the radio.
    Just my .02
    "If it aint broke don't fix it" is like a 4 letter word.
    <a target="_blank" href=http://www.phatboy.alloffroad.com>PhatBoy.AllOffRoad.com </a>
    Charlie
  13. 88jimmyoungowner
    88jimmyoungowner 1/2 ton status
    Nov 20, 2001
    425
    georgia-rome
    this may seem stupid, but the tail lights on that modle year have different fillaments for each. My brake light worked, and my blinker did not. I replaced the bulb, and amazing- it worked!! I dont mean to be rude or anything, but i hope you checked it.
    16, 88 jimmy, kearning, but still need help
  14. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Yes, the fronts are dual filament. They are parking lights as well as turn indicators.
    Haze gray and underway...<font color=blue>or blue, in my case.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/album/26246038MbQsYWKcbo>U.S.S. Nimitz II</a>
  15. bking
    Jan 4, 2001
    176
    So, does this mean that if the flash filament has gone (Grille) that this would stop the sidemarker light, and the turn ind on the dash from working? but let the rear work ok?
  16. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Did you check the ground? Also take a test light and check at the socket. If no power is there then go to the wiring harnes right under your driver's side door and check again by probing a wire. It is pretty common for the wires to break where they go over the fuel tank. I have seen quite a few with that problem and even more with the ground problem since here in MN they like to rust out.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  17. Grim-Reaper
    7,385
    Atlanta
    The old bulbs were low on blinker fluid.
    Look in the plug...probably have some corrosion in the socket. The new bulb is corrosion free so it made enough of a contact to work You can proably sand or file the contacts and cure the problem. Get yourself some Diielectic grease and put it on the contacts and the socket rim to keep air an moisture out.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  18. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Hey CaptCrunch thanks I was waiting for someone to answer with that answer I too had the parking lights but no brake lights(drivers side) I looked and tested the rubber connection and all that too but lost it over the tank so that will be the next thing to check -thanks,mike
