tail light malfunction?
Discussion in 'The Garage' started by 88GLAZER, Sep 24, 2003.
  1. 88GLAZER
    88GLAZER 1/2 ton status
    Nov 19, 2002
    111
    West Virginia
    If I turn the driverside blinker on, it is fine, but when i turn the other side on, they both come on, but not as bright very dim. when I turn the headlights on I lose all rear lights? what the funk!
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Bad ground's. Check and clean all the ground's, at all the light's. /forums/images/graemlins/grin.gif
  3. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    I agree. Check your body ground from the battery, too. It may not be causing the tail light problem, but it may be causing problems that haven't yet reared their ugly head.
  4. 85BlazerFan
    85BlazerFan Registered Member
    Dec 2, 2002
    14
    Audubon, NJ
    OR
    Passenger side blinker fluid level is low. /forums/images/graemlins/ignore.gif
    (Sorry, that's the first thing that popped in my head after reading your post) /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    To get to the tail light grounds, remove the tail light lenses, then the housings. Now you can see the ground wire on each side, attached to the body on the bottom of the opening. /forums/images/graemlins/thumb.gif
