tail lights dont work FIXED
Discussion in 'The Garage' started by big83chevy4x4, Jan 17, 2004.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    nothing works except the blinkers, no tail lights and no brake lights /forums/images/graemlins/eek.gif what could be causing this problem? my dad says that it blinked on when i hit a bump or something. i need to get this done ASAP. its kinda stopping me from trying to find a job. any input is apreciated. Thanks TJ
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: HELP my tail lights dont work
    CHECK YOUR GROUNDS!
    Edit:
    Seriously, make sure all your grounds are clean, hitting a bare spot on the frame and getting a good connection. It's amazing how far that will take you.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    well i hope you arent looking for a job as a mechanic.. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif but seriously, get a good check on the grounds in the system.. check for power to the bulb as well..
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i havent even looked at it yet, to damn cold /forums/images/graemlins/mad.gif but yea that the first thing i would check. i have a couple of ideas just want a couple more.
    well for most of my family, friends, and some neighbors, i am a mechanic /forums/images/graemlins/thumb.gif i jsut really hate electical on my truck /forums/images/graemlins/angryfire.gif DAM P/O /forums/images/graemlins/angryfire.gif
  5. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Well try the ground thing first but also check for a lose connection on the headlight and turn signal and brake light switch first..if not a lose connection the start with the headlight switch first...then go from there ..They are all fairly cheap to replace the only one time consuming is the turnsignal switch..
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I had that prob on my drivers side one, and it was the ground that goes into the bulb housing, not the one that went to the body.
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i pulled the lights off and on the driver side 1 wire to the tail light was broken and both for the reverse lights were broken right at the light socket
    then i crawled under and found what a previous owner did to it.
    when he wired trialer lights in, he cut all the wires just before the connector and used wire nuts to hold in the wires for everything. there is like 4 wires hanging and 2 wire nuts missing.
    looks like im going to have to rewire the tail lights in 22* and 2 inches of snow that is under my truck /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  8. Confedneck
    Nov 1, 2002
    5,236
    sounds like it should be loads of fun.. gonna solder those connections??
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I suggest going to the junkyard and getting yourself a whole wiring harness that is still in one piece. That way you can fix his hack job and plug it right in, won't have to mess with re-wiring the whole truck in the cold.
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i already got one from one of my parts trucks /forums/images/graemlins/thumb.gif
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    I just got done fixing it. i had to cut the trailer wiring out and wire it back toghther. both tail light, both brake lights, both blinkers, and one of the reverse lights work. Its getting colder out and didn't feel like trying to fix 1 light that im not going to need.
    maybe now i can go apply for a job /forums/images/graemlins/thumb.gif
  12. Confedneck
    Nov 1, 2002
    5,236
    SWEET!! feels good fixing a hack job, dont it?
  13. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yea it does, and yes i did solder the connections
  14. Confedneck
    Nov 1, 2002
    5,236
    well congrats on kicking its ass! /forums/images/graemlins/thumb.gif /forums/images/graemlins/truck.gif
