Tail lights
Discussion in 'The Garage' started by mudjunkie 82, Mar 13, 2005.
  1. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    My Tail light Assemblys do not sit flush with the metal, They stick out slighty. Is there different ones for different years? The LMC cataloge says 73-87??? Mine is an 82-PU:confused:
  2. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    I think what your seeing is pretty normal. You may be able to trim the plastic down on the back side to drop the lense in further but not sure if you can go to far or not. I don't think I've ever had a set sit flush.
  3. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Not a truck, or a good pic for that matter,,:grin: but mine stick out 1/4 inch or so, and its a 85. Id have to look , but i recall theres a strip of rubber between the lens and the sheetmetal .Good luck , Jacob :)
