Tail pan replacement
Discussion in 'The Garage' started by 84mudmachine, May 27, 2005.
  1. 84mudmachine
    84mudmachine 1/2 ton status
    Dec 23, 2003
    184
    Kansas
    I what to get some ideas of how to replace the tail pan. I thought about some tube steel instead of the tail pan from LMC. Has anyone done this? Another question is if I need to remove the gas tank before welding in a new one?
  2. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    I replaced mine a few years ago with one from JC Whitney. I cut the old one out with a saws-all and I unbolted the four rear body mounts and lifted the body up off the frame just enough to squeeze the new one in. PIA, but it worked out well in the end.
    The hardest part was installing the tailgate and getting it aligned right.
  3. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    Did you weld it back in? If you did, did you remove the gas tank?
